RichardS
N/A
I've decided to replace the gas hose which runs from the regulator to the cooker. I'm going to need about 8m of suitable hose so feeding it through from the gas locker at the back of the boat is going to be a tricky job and I need to make it as easy as possible.
The current black "rubber" hose is stamped "Accuflex BS3212 1991 / 2 / 6.3 High Pressure LPG March 2006". The external diameter of the pipe is around 16 - 18mm.
The cylinders on the boat are blue butane R907.
This is the fitting which is on each end of the gas pipe:
The fitting is stamped "FF 3/8 SAE". I don't think that I'm going to be able to feed the new pipe through with this fitting on each end, although I could obviously feed it through with the fitting on one end only.
My questions are:
I assume that the ID of the pipe I require is 6.3mm (1/4in)? The smallest approved OD I can get will make feeding through easier, of course.
I assume that the end fittings are imperial 3/8 thread and the FF refers to the domed sealing surface?
I won't be able to crimp on the fittings myself, although I could have it done somewhere, but at one end only. However, if I cut off the current fittings will I find a proper spigot inside the pipe so I can simply push it onto the new pipe and secure it with a couple of jubilee clips, or similar, at each end?
If I can't use the existing fittings, what DIY replacements do I need?
Many thanks for any assistance.
Richard
My questions are:
Richard
