help - Strange NASA BM1 battery monitor behaviour
Why 3 wire ?
You made me think then Vic as I fitted 3 to keep an eye on the battery banks for domestic, starting and genny.
Extract from another supplier.
Pinout
•Red: Positive Power supply
•Black: Negative Power supply (0V) - also used as the negative measurement voltage
•White: Positive measurement voltage
Remember this is the 3 wire Version module, which means with the supply voltage maintained, and with the measuring voltage at 0v the display will still be on, so you can see the full swing of the measuring voltage from 0v to 32v. Unlike 2 wire versions where the display will start to dim and turn off when the measuring voltage starts to drop below 5v, since the 2 wire version uses the measuring supply to also power the unit.
Pinout
So this needs a separate battery or an isolating power supply module.
