Help - Steam / Smoke
Just you're satisfied you've got a clear run from the water pump, the only thing I can suggest is check for air leaks in the system. Mine saw some improvement after I applied vaseline to help seal the sea strainer lid
Both my 805‘s with the same unit produced that amount of steam.
if no black clag on the transom / platform and exhaust and cooling ok no problem
presume exhaust is above waterline at speed
Yes, almost all owners of these engines report the same condition so I conclude it's a characteristic of the engine and not a fault. The amount of steam does increase if, for example, the exhaust elbow has reduced flow, the prop has some fouling or the bottom is fouled.
