PetiteFleur
I have foam extinguishers in saloon, clipped to the saloon table leg & in the aft cabin and an automatic Halon replacement in the engine space.
It is interesting to watch the Yachting Monthly crash test video
And breathing, that stuff is vile.For me the biggest drawback of powder is the visibility issues it causes when set of in a confined space.
Point taken but why use anything that can cause more damage when better alternatives are available, and as said previously powder won't cool the engine and other burnt areas.I think that's a bit of an old wives tale, unless you don't have adequate air filters on your engine. It can damage things metallic and electrical items if left in contact long term, but if the thing is on fire, is any potential damage caused by an extinguisher really your main concern? Have you been onboard a boat after even a small fire. The mess and damage is incredible.
For me the biggest drawback of powder is the visibility issues it causes when set of in a confined space. I think many are not aware of that.
Powder has no place on a boat as it will destroy a running engine......
Never understood this. If you had an engine fire wouldn't you stop the engine before trying to put the fire out?
Would you remember to do that? Once the red mist hits all sorts of daft things happen.Never understood this. If you had an engine fire wouldn't you stop the engine before trying to put the fire out?
You must also remember where you position any extinguisher. It needs to be in a position where it can be close to an exit point from the cabin. You don't want to be in a position where you to go looking for it.
WIth an automatic FE, it may go off before you even know there is a fire.
What you need is a smoke/fire detector inside the engine compartment and a remote activated fire extinguisher
Hmm, not so sure about the fire sticks. If they’re cheap and store ok, cannot see the harm in having a few on board. But don’t think they could replace regular extinguishers. Having seen the water mist in action, reckon that would put out the demo FSS fire with a lot less time/fuss/mess.
Interesting suggestion. A quick search turned up some Plastimo ‘gas’ extinguishers with remote activation. Couldn’t seem to find a price anywhere, though, which doesn’t bode too well for affordability/availability.
Would installing a ‘key hole’ type aperture in the companionway steps that was sized to take the horn of a CO2 (manual) extinguisher achieve the same thing? Plus the CO2 could also be on hand for use elsewhere, whereas a fancy engine room extinguisher is obviously for that space/job only.
Looking at the way a hand operated extinguisher is operated to me it would be quite easy to fit a remote cable cable like an engine shut down cable or a bicycle break cable. You would need to remove the safety pin to allow remote operation.
