Help me identify bulb for navigation light
ProDave
5 Sep 2010
Alness / Black Isle Northern Scottish Highlands.
I need a new bulb for our navigtaion light. but it is slightly odd.
At first glance it looks like a pretty ordinary festoon lamp, about 44mm long (1 3/4") but the end caps are different.
A normal festoon lamp has conical shaped ends that fit into a hole in each of the terminals in the lamp holder. But this lamp has conical indents in each end cap and there is a point on each lamp terminal that sits into the indents on the lamp. A sort of "inverted terminal" festoon lamp.
I am sure it is a standard type of lamp, and as usual, it is a case of asking the knowlegable on her what is the correct name for this type of lamp?
Oh and I want the replacement to be LED
ProDave
5 Sep 2010
Thank you.
So a quick search suggests Holt are the only supplier of a dimpled festoon lamp for just over £10. a plain ordinary conical shaped one can be had for about £3
The good old marine premium, lets deliberately make it different.
I can feel the lamp holder being modified now as a matter of principle.
VicS
13 Jul 2002
Thank you.
You will find dimple ended led festoon bulbs on the Boat Lamps website
Festoon LED Lamps
( Note that they are closed for holidays until 8 Sept )
Use coloured or warm white behind coloured lenses and cool white for white lights.
Martin_J
19 Apr 2006
Portsmouth, UK
I have never used (or suggested) leds as replacement in light fittings that would have been certified whilst they were used with a single vertical filament bulb that would give the correct cut off angles.
It seems like nobody is so concerned these days about light sources that are wider, thus giving a less than perfect cut off angle.
However... Bedazzled also supply dimple ended festoon LED bulbs, in cool white, warm white, red or green, but more importantly they are fused.
12 volt and 24 volt LED Festoon LED bulbs from Bedazzled
Martin_J
19 Apr 2006
Portsmouth, UK
And as VicS mentions, LED colour choice is important, but the colour spectrum of the LED is never quite matched to the lens.
Going by...
Would seem to imply that the tricolour suggestion is not optimal for all the sectors..
B27
26 Jul 2023
There seems to be a product description problem, their masthead lamp is missing 180 degrees of illumination.
I think it's 'masthead' not all-round white.
'masthead' + 'stern' = 360 degrees?
AKA 'steaminig'.
Looking at the way you can see the LEDS through the lens, I doubt the cut-off is very accurate?
But then as the man said, accurate red/green cutoff just shows up our poor course keeping!
Biggles Wader
3 Mar 2013
London
Boycott this company, they're dishonest.
"Free Delivery on UK mainland orders over £100 excl. Highlands"
It says excl. Highlands rural in the ad. Does that mean only rural bits of the highlands or any rural areas? Either way it might be deemed discriminatory but hardly dishonest if clearly stated in the offer.
Stemar
12 Sep 2001
To be fair, check with couriers how much they want to deliver something from SE England to Edinburgh, and how much to an isolated address 20 miles from Thurso. It's tough for the person wanting stuff delivered, but a delivery driver in Edinburgh can do do a delivery every few minutes, but the one based in Thurso may only be able to do one an hour.
Do Royal Snail still charge the same for anywhere in the country? If so, it may be why they're more expensive than others for urban stuff - the urbanites are subsidising isolated communities.
Aja
6 Nov 2001
Unfortunate that the original concept of the Post Office is no longer. 1d postage anywhere no longer applies.
Post Office managed it then - went not now.
penfold
25 Aug 2003
On the Clyde
The reason the mail is struggling is because neo-liberalism is apparently the only way things can be done; it's also the reason couriers do the aforementioned discrimination against ~20% of the nation, because they can.
