Help me get my Yam 2B running again
chris-s
24 Apr 2019
We’ve had this wonderful engine for five years, it’s never failed to start on the first or second pull, I’ve dug it out of hibernation and it’s no longer happy.
The first dozen or so attempts to start it felt ‘tighter’ than I recall. Never noticed this before, but now feels like it did last season after many starts/attempted starts.
It will run for a few seconds, how long exactly depends on how long I left it before retrying but never for more than four seconds. It will not fire with the choke on, this is different than before.
Almost certainly a fuel issue.
Fresh fuel, plenty of flow out of the pipe to the carb, fuel in the bowl, clean bowl, stripped the carb, not that there is much to it, nothing looked dirty or blocked but blasted it thru with carb cleaner anyhow. Checked the little o-ring that would be the inlet manifold gasket if it had one and made sure to give it a good push-home when refitting. Also fitted a new plug.
No difference to before. The only thing I haven’t yet tried is to squirt some fuel in the air intake as it starts to run.
Anything obvious I have missed?
Have you physically proved the jet by using fuse wire or similar to push through the hole? Doesn't take much to block or partially block.
I'll be interested to hear what finally solves the issue.
Best of luck
Somebody will be along soon to suggest that the float and its needle aren't right, and that the float height might need checking. Good luck, it'll not take you too long.
Best of luck
I removed the jet and could clearly see thru all the holes before using any carb cleaner.
That was my first port of call. It’s not adjustable on this carb and all looks clean after removing it, didn’t appear to be sticking and blasted thru with carb cleaner anyhow.
I was going to suggest checking the fuel filter attached to the fuel tap , because I had the same symptoms with my engine when the fuel filter was blocked, but you've said there's plenty of fuel flow so that knocks that idea on the head. Sorry.
I'm wondering why it felt tighter when trying to start it than last year. Doesn't take much extra resistance to stop a 2 stroke from running as I found out with my malta a few years back.
That’s in the back of my mind too, but I can’t work out how that explains the behaviour I’m now seeing, where if I try to start it immediately after it stops it barely fires, leave it a couple of minutes and it will start right up and run for three or four seconds, leave of for less and it will start but run for less time. That’s a fuel issue.
Thanks for all the replies, doesn’t look like I have missed anything obvious or a hidden trick with this old engine. I’ll strip the carb again and take another look.
Would that be consistent with it running on whatever was in the float bowl, which is refilling more slowly than fuel is consumed by a running engine?
Four seconds doesnt sound long enough for a full float bowl, but perhaps if the float is set low the "full" bowl isnt really full.
It should run for a lot longer than 3-4 seconds on a full bowl of fuel.
Been stood awhile. I might suggest sticking piston rings. If they are then the engine won't be sucking in air properly. Remember engines work on the suck and blow principle. Since you reckon you have checked the fuel system thoroughly you might need to look elsewhere.
Success! Well, sort of…. It was bugging me that it felt tighter to turn over, I removed the plug to eliminate any compression effect and it was still a bit tighter than a felt it should be. Removes the bottom end of the leg and it the while gearbox felt tighter than I expected. Put the engine-less-gearbox end in the water bucket and it fires up instantly and purred lovely.
Stripping the whole bottom end down I can’t see anything obvious, maybe it was all gunged up. Bearing runs freely, bushes seem smooth and not binding.
However, I’ve now created a new problem when removing the bottom end… the water pickup pipe didn’t release itself from the top of the pump, instead it fractured at the top. It looks like a simple brazing job and the power head came off super easily so it will get a good going over whilst it’s in pieces. The only thing I’m not sure about is the angle on the top of end of the pickup pipe, but I’ll have a look online to see if I can find some pics.
Thanks to all who commented.
Chris
