chris-s
We’ve had this wonderful engine for five years, it’s never failed to start on the first or second pull, I’ve dug it out of hibernation and it’s no longer happy.
The first dozen or so attempts to start it felt ‘tighter’ than I recall. Never noticed this before, but now feels like it did last season after many starts/attempted starts.
It will run for a few seconds, how long exactly depends on how long I left it before retrying but never for more than four seconds. It will not fire with the choke on, this is different than before.
Almost certainly a fuel issue.
Fresh fuel, plenty of flow out of the pipe to the carb, fuel in the bowl, clean bowl, stripped the carb, not that there is much to it, nothing looked dirty or blocked but blasted it thru with carb cleaner anyhow. Checked the little o-ring that would be the inlet manifold gasket if it had one and made sure to give it a good push-home when refitting. Also fitted a new plug.
No difference to before. The only thing I haven’t yet tried is to squirt some fuel in the air intake as it starts to run.
Anything obvious I have missed?
