taormina
Evening all,
Been away for week on the boat, fantastic week, visiting st Kats, the medway marinas, crouch and back to Blackwater, fantastic weather, really enjoyed it, small glitch though, over the week my port kad32 made no responce to turn of key, several times other than dials and lights going out, its as if you are trying to start in gear, messed about with wiring under throttles, checked connections then it started, ok, then did it a again couple of days later, checked connections again, nothing, getting worried by now, so down in engine bay checking connections, everything seems good, boat serviced by volvo paul last year, new battries etc so not them... pressed reset fuse button and checked connections in the black box, fires up pronto... ok again for couple of days, same again not starting, pressed reset, checked relay connections etc, black box, fires up pronto again, Whats the problem? had new bowthruster fitted in the winter... Is it a relay problem? seems when i check connections in the black box it fixes.....HELP!!!
