johnkeith
Putting new heads into my boat and looking for tips on fitting the outlet hose to the seacock. So far I've spent about four fruitless hours trying to do this job. I've tried putting the pipe into boiling water and also hammering a softwood plug into the pipe to widen it. Also tried putting washing-up liquid in pipe and on seacock to ease the thing on. So far nothing has worked. The piping has the following writing on it ' KD- Trident VAC XHD SANITATION and POTABLE WATER' is a more flexible type of hose available which will stretch more?
The seacock has a c.5mm lip on it which adds to the difficulty of getting the hose on - should I consider unscrewing the end fitting and replacing with a fitting which dosen't have a lip, if such things are available. I'm a bit worried about this option as the throughhull part of the seacock has not been fitted with a proper wooden backing plate and therefore there is the possibility of damaging the seal at the hull.
Help please!!!
John /forums/images/graemlins/frown.gif
Help please!!!
