vyv_cox
Re: No ... its WIND pressure
Yes, I realise that but the pressure is not acting on a vacuum, it's acting on the same stuff at the leeward side of the sail. So you have to subtract more in the case of moist air than you do for dry.
That's a good site you found but I will check the values given. The figure for Force 11 is 660 N/m2, equivalent to only 13.7 lb.ft2. See the much greater numbers that I found in the "Bruce Anchors" thread. I was searching for a couple of hours earlier in the week when trying to calculate anchor warp loadings under maximum conditions, but I didn't find that one. I did find several American sites that give basic data and the coefficients that need to be applied for differing conditions. The UK codes do something similar, my daughter is very familiar with these and she has given me some formulae. I'll check them against the site values.
