MagicalArmchair
once the bolts are out, then a gentle knock with a rubber mallet should do it, and then perhaps a poke with progressively more aggressive tools as needed. I have some nice plastic cold chisels but they are little specialist for a one off!
as long as where the oring sits is clean and unmarked your good.
Thanks for the tip - I'm not happy with some of the little nicks in the copper gasket that houses the rubber gaskets (I'll need to gently remove a couple of small burrs I've created), so I've invested in some of these: Expert by Facom 4 Piece Composite Plastic Scraper Kit | Interior & Trim Tools to get the other end off.
The tightening sequence and method posted by jwfrary is sound. Personally, i would not use a torque wrench on these, there is no need and you could do more harm than good.
"snug them up by hand based on experience" is the best way
Leave torque wrenches for this type of job to the armchair experts.
I find they are either perfect or knackered! Had an engine in not long ago where the customer tried to take the unit off and broke every stud! But it’s rare. - safe than-sorry!
Thanks for the tips, I'll inspect the studs carefully once I have cleaned them all up. They look pretty good, however, if I am in any doubt I will replace them. On refitting all these bolts should I use copper slip on them? Some of these are steel into aluminium, some are steel into steel (those that fit the exchanger back on to the engine), and all will be subject to large amounts of heat. Apologies if I have asked this before above!
