MagicalArmchair
I have the Heat Exchanger back - and it appears I have a lot of time now to adore it and get it ready before I fit it to the boat (seeing as I'll next get to see the boat in October
). The steps I want to go through to prepare it (let me know if these sound correct, or if I have missed anything.)
- Remove remains of the old Gasket between the engine and heat exchanger. It's pretty baked on, so I'll try using some brake cleaner on it and use plastic scrapers to remove it (razor blades etc being too hard for the soft ally).
- Take the raw water chamber apart and inspect the stack. Soak it in white vinegar (I do have some Rydlyme mind you that I was saving to flush the whole raw water circuit with, I could use half a litre of this instead I suppose...).
- Put the raw water chamber back together with the new rubber gaskets supplied by Parts4Engines, greasing those up with a little marine grease. Pressure test the raw water chamber again to 15psi.
- Test the thermostat whilst its out as per the workshop manual.
- Degrease the Heat Exchanger, mask it up, lightly sand the old enamel, wipe down, and then respray the heat exchanger.
- Use air gun to carefully spray through the exhaust passages and fresh water passages to remove any debris from the above.
