Head torch recommendation?
Skylark
4 Jun 2007
Home: North West, Boat: The Clyde
My good old faithful head torch is showing signs of age (strap elastic)) so probably time to consider a replacement.
There seems a bewildering choice available, most of which have features for which I have no interest. I don’t want to press a button half a dozen times to select the intensity and number of LEDs illuminated, nor do I need a flashing light, my disco days are long since past ?
I’m looking for any recommendations for a simple, basic head lamp with selectable red or white light (only!).
I’d prefer battery rather than rechargeable as that would be another unwelcome complexity for something that gets used relatively infrequently.
Many thanks in advance.?
Rappey
13 Dec 2019
Im not sure you will find white, red and no other functions. I have a led lenser (they make some of the best torches available) with a focusable beam. When you finally find the red function it stays there, turn it off and it comes back on using your last setting so thats something.
A usb port for a rechargable one surely would be better as an on board usb charger is very common place nowadays?
Or buy a handfull of the cheapest headtorches you can find.
I do agree cycling through the functions is annoying. My main torch has around 7 different functions, then just to complicate it even further they are also programmable so it only does two things , or 3 and then beam intensity etc...
Refueler
13 Sep 2008
Far away from hooray henrys
I have a couple ... bought cheap in local supermarket .....
One has a lens that pulls in / out to narrow / widen the beam depending how close / detailed you are looking at ... with also a choice of high / low beam ...... 4xAAA with LED's ..... Excellent and cost about 5 euros
Second is same but with fixed lens .... again about 5 euros.
I used to pay good money for so called quality item .... but in reality ? No better.
You ca of course buy haedstraps on their own ... I have a bag of 10 I bought of eBay .... I fit micro vidcams to and various .. so if your headlamp is still good but just needs a new strap ?
Example :
Elastic Headband Helmet Strap Mount Head Strap For Bike light Headlamp Band JL | eBay
stu9000
8 Mar 2008
near kingston upon thames, surrey
Goldie
29 Sep 2001
Nr Falmouth, Cornwall.
[QUOTE I'd be interested in recommendations for a quality equivalent if it didn't do the silly four options. I just need non flash white and non flash red. [/QUOTE]
The RAW Pro by Exposure Lights is fantastic. Expensive yes, but if you’re an RYA member there are good discounts to be had - see Member Benefits page.
Skylark
4 Jun 2007
[/QUOTE]
The benefits page doesn't give a lot of info, instead it tells me to register with Ocean Safety RYA Instructor Store. Seems a bit of a faff. A Google search shows that it has a List Price of £125 and has a single click operation to get different power settings and different colours. There's nothing more frustrating than someone on a boat at night scrolling through switches to find a simple red light, normally night-blinding the rest of us in the process. Unnecessarily complicated for my simple mind. but thanks for the post :)
Skylark
4 Jun 2007
Skylark
4 Jun 2007
Oh yes it is - It does have red so fits the bill. Sorry for my confusion.
According to the spec, it's looking good so thanks for the post. In addition to my confession of being a dinosaur, I also from the "trust no one, check everything" school. I've sent a message to the ebay vendor. They replied almost immediately by saying "we've never been asked that before so we'll check and get back to you". Helpful seller.
Roberto
20 Jul 2001
Lorient/Paris
sybrancaleone.blogspot.com
I have two Petzl lamps, the type with no textile elastic bands but a tiny (1mm) rope and the spring coil plastic element. At first I was not convinced but the unit without straps is very compact, can be put in pockets, etc.
Three possible lights: strong fixed white, weak fixed white, fixed red; the on off switch has a memory with the last setting, the settings are swapped by keeping the button pressed for say two seconds.
They are more than 8y old models and I do not remember their names not could I find them in the catalogue, Petzl make a huge number of different varieties I am sure they have something similar. Not cheap, by memory 30-40euro.
Goldie
29 Sep 2001
[/QUOTE]
Discounts can be up to 40% depending on category of membership and the reason I particularly like this light is that you can start it on ‘low red’ thus avoiding the very issue that you describe.
duncan99210
29 Jul 2009
Winter in Falmouth, summer on board Rampage.
djbyrne.wordpress.com
The best solution I’ve seen recently is this one of eBay Military Army 4 LED Head Torch Red Filter Headlight Lamp Lens Torch + Batteries | eBay. It’s a basic head torch which uses white LEDs but has a sliding filter which slips into position to produce the red light. Does away with multiple button presses and you’ll only ever get red light if you keep the filter up. No idea of quality or waterproof but it’s not expensive.
Alternatively there’s the military type right angle torch that you can hook onto your lifejacket fitted with a red filter like this one Olive TL-142 Field Torch - US Army Small Green Right-Angle LED Flashlight Filter | eBay.
