Hatch runner/slider
PabloPicasso
12 Feb 2010
I'm rebuilding a sliding main hatch. It did have brown plastic like strips in the gullet for the hatch to slide on. However these are worn out/broken. What could these strips be replaced with?
I used RG 1000 RG1000
I had some in stock already so just cut a strip. However, an enquiry would find out if they would cut a couple of long strips of the correct dimension for you.
If you look on their site you may well find an alternative material that suits you better ( all the items have full descriptions & uses)
When mine wore out after 15 years, I turned them over, they should be good for another 15. I'd use something like Formica if they needed changing again. I think the originals were Tufnall.
I realise that OP's hatch is already designed and most likely just looking for material to replace worn parts. But thought it might be interesting for some to see my hatch system that has stood test of time ... boat built and this installed about 1973 ....
The flat plate has countersunk screws into the teak standoff ... and hatch slides nicely apart from winter - when a quick silicon wipe or spray keeps hatch from icing up.
If you cannot buy HDPE, Acetal or RG 1000 in strip form you can try what I did with some nylon on another job
I bought some rod. I cut it down the centre which gave me 2nice domed strips with the cut edge facing down to the fixing surface. I drilled & countesunk the screws through the domed surface & the 2 halves made nice runners.
This was for the sliding part of a machine & it has worked Ok for a couple of years.
But I do have a band saw. I could have done the same with a circular saw. One has to purchase a larger than expected diameter because the sawcut does remove some of the width of the finished strip. It is a cheap way of doing it & acetal & nylon can be purchased as rod from many supplies including the link I gave earlier.
To my mind, a flat surface will require less effort to slide the hatch than a curved one, as the weight will be more spread out.
I' ve got some strips of PTFE which I intend to use when I can get around to it.
Edit: It's acetal from Direct Plastics
