Halyard questions
KevinV
12 Oct 2021
So, having rewired the mast, sorted out the mess at the masthead, and mostly done the rigging it's time to wash/check /replace the halyards.
Taking them off there are different kinds of ropes, shackles, knots, etc.
Particularly the use of three strand raised an eyebrow - I can sort of see that a bit of elasticity in the topping lift might be useful, but in a genoa halyard??
I can also see that not everyone can do a splice, but there are three different knots - which is best? Also the hard eye on the topping lift makes sense to me, even if it's noisy, but why on the second genoa halyard?
Then shackles - I like the half-turn ones for the mainsheet, and snap-shackles for the spinnaker, but the range here is going to baffle any inexperienced crew.
So, here they are:
From top to bottom:
Spinnaker halyard
1st genoa halyard
Topping lift
2nd genoa halyard
Main halyard
Spinnaker pole uphaul
Secondary question - why the loop at the end? Is it to put over a cleat (there are lots of cleats) to stop the halyard running away if caught by the wind when loose?
Noob questions I know, but I've always sailed other people's yachts and just worked with what was there 🤷‍♂️
johnalison
14 Feb 2007
Essex
I’m a fan of the halyard knot but the version that came with my then new boat was tied with the tail taken back through the loops alongside the standing part.
LadyInBed
2 Sep 2001
Me - Zumerzet Boat - Wareham
montymariner.co.uk
Like this. It's how I tie mine, but with three turns.
William_H
28 Jul 2003
West Australia
On my little boat for jib and spinaker halyard I just have a plain end on the rope. It is attached to the jib or spinaker with a bow line. (jib is hank on) What this means is that every time the halyard is connected the knot is ina different place so wear of halyard at sheaves up the mast is ina different palce so increasing life of halyard. Plus saves weight of shackles up the mast. ol'will
Refueler
13 Sep 2008
Far away from hooray henrys
I removed the shackle previous owner used with the main halyard - it added a short length and stopped the main being hauled up taut ... I just use a plain end made fast to mainsail head now.
Similarly I removed metalwork from genny sheets - previously I liked the snap swivel similar to OP's top line ... but after having it whack me - I decided soft rope was better !!
My Spinny halyard is plain end as well ...
I am not a user of the halyard hitch as I prefer a non tightening hitch that I can easily undo when needed.
