MapisM
No need to invent anything particularly smart, I reckon.Agree all that, although the 24v backup pump option would also need some smart switching (or at least i'd need a generator shut down alarm)
Just put along the 24V pump wiring a "normally on" relay, actuated by the same 220V of the gyro.
As soon as you turn on the gyro switch, the relay goes off.
You turn on also the 24V pump switch, and nothing happens (because the relay is cutting the line).
If and as soon as AC goes off, so does the relay, hence turning the 24V pump on. :encouragement:
Btw, you might attach to the very same relay also an alarm, if you want to be alerted of the missing AC power...
