jrudge
Was part of the visiting crew last night.
Prices and dimensions
MC5 e14000 39x39x42 110kg
MC10 e18500 48x48x49 235 kg
MC20 e24000 61x61x63 436 kg
MC40 e52000 83x83x85 785 kg
MC80 e79900 95 x 95 x 96 1084 kg
All PLUS vat in Euros.
All the numbers refer to boat weight in tonnes - 5 = 5 tonnes etc
Install is claimed as bolt on and forget. Clearly what you bolt it to is the issue !!
A big point is that to get 20 you could use 2x10 or 4 x5
This might not seem economic but if you consider that suddenly instead of taking the boat to bits (squadron 65) you can use 2 smaller units that might fit somewhere, and dont need to be mounted next to each other it starts to make sence. This same feature may let you use 2 free spaces - bottoms of Laz and somewhere in ER for example. In a S 65 there is a HUGE space below the lower companion way in the middle of the boat. So a number of smaller units could be deployed etc and no useable space lost.
The consumption is 600w/1500w/2200w/3500w/4800w so running off an inverter was not considered practical by them. It would be like running the kettle for 8 hours !
They are working on a mod that uses an inverter to boost voltage to 400v during spin up which lops about 10 min off the spin up time.
A squadron 58 for example is 23 tonnes dry so an MC20 would sort of fit that bracket ( the next one being a 40) and if that was not good enough you could add a MC5 to the mix.
An MC20 would be E24000 + vat so about £25k plus fitting
A seakeeper 5 ( 20 tonnes also ) is $32,340 + shipping from USA and VAT. - probably £35k landed + install costs.
Weight 790 lbs (358 kg)
Dimensions 29.7 L x 30.0 W x 24.7 H (inches)
0.755 L x 0.763 W x 0.626 H (meters)
Interestingly it is lighter than the MC20. but the MC20 is smaller by 10cm in most dimensions
On the face of it you could stabilise an S58 for not much more than £30k which is starting to look attractive
