LadyInBed
The often recomended product for green organic growth is Patio Magicthe cover is only a year old & just a little grubby, with a few spots of green organic growth.
Have you tried a Pressure Washer?
But not too close!
Some people are such experts and being experts will enjoy criticising anchor testing, reptitively. Challenge them and ask them to develop and describe a test protocol - and they slink off, until they think their criticism has been forgotten - and they repeat the message. But they never come up with an anchor test protocol.
Thanks to investigative work, we have better tether hooks for safety harnesses, shackle specifications have been downgraded to reflect reaiity, chain hooks have been withdrawn ...
Pointing out the flaws in a test protocol doesn't require producing a better one - that's the tester's job. I write as one who spend some years of my life developing international standardised test protocols in a completely different area.
A gallon?? A tiny tub of Y10 lasts me years. I don't think I'd ever get through a gallon of the stuff.
Ditto. I have some from left from a tub bought off e**y (the auction site) ages ago. Last year I mixed up some, put it into a garden sprayer and mist coated the topsides and deck. Perfectly white in 10 mins...I have the same feeling. Bought 500g of powder many years ago for under a fiver and still have a good bit leftAlso useful for removing the light specs of rust on gantry and bimini frame
Most testers think their protocols are as good as is practicable. If they could develop better tests - they would.
And your point of the hook is?
The problem with product tests is that it is nigh on impossible to test any product against every possible task it is likely to be used on. Cleaners are a particular difficult one. ...
The point is that it is still for sale and not, as a result of claims by amateur testers, "withdrawn".
Does anybody here believe/take any notice of PBO or YM gear tests/product comparisons?
Needing to give my canvas work a spruce-up I happened to see one on just the products I needed & seeing the “Best on Test” which stood out way above the others was also reasonably priced I duly bought some.
Here comes the surprise: half an hour of scrubbing on my sail cover, carefully following the instructions, had absolutely zero effect; the run-off didn’t even appear discoloured.
I feel like the kind of sap who’s been talked into buying hair restorer from a carnival shyster & found it to be syrup of figs...
Fair point but the cover is only a year old & just a little grubby, with a few spots of green organic growth. When I can summon up the enthusiasm I’ll try again using laundry detergent & will provide an update. If similarly ineffective I’ll eat humble pie ?
That is just the natural tendency for flesh to lose its elastcity as you age.I understand your disappointment .
Like finally finding a make of underpants that hold you in and are comfortable. Only to find that everything has gone rather slack after just one wash.
Who said it had been withdrawn?
Thanks to investigative work, we have better tether hooks for safety harnesses, shackle specifications have been downgraded to reflect reaiity, chain hooks have been withdrawn,
Most people who test for the leisure marine industry are 'amateur' testers. They do the best they can. What on earth do you expect?
Now - excuse me, I'm off to check up on the uses of syrup of figs. We have a fig tree, maybe it will be more satisfying and focus than trying to pander to a grumpy Scot
avoid the wall paper paste. It can be a mess to clear up (it is glue, after all). Try mixing OA (saturated solution) with a thick dishwasher liquid, like "Fairy Liquid", instead. A One to One mix usually results in a thick enough gloop that stays on a vertical surface of GRP long enough to work.Y10 is good but, I think you would have been more impressed if you had bought oxalic acid crystals and some wallpaper paste, enough to make up a gallon or more, at half the price of small can of Y10Too many tests have results designed to keep advertisers happy.
No. Just not enough detail and a total lack of methodology.Does anybody here believe/take any notice of PBO or YM gear tests/product comparisons?
