Guardrail Knot/ lashing
muzzaman
22 May 2008
Does anyone have any suggestions as to a suitable knot to use to tie off my guardails to the pulpit/pushpit?
I have attached a very poor picture of the current one.
Jabs
22 Jun 2011
Bursledon
I thought a shackle at the Pulpit and a lashing at the stern/pushpit was best.
Basis is that you need to be able to cut the stern to get a MOB back??
Tony
muzzaman
22 May 2008
Yes, I intend keeping the lashing at the stern end for that very reason. On the basis that the string used for the lashing is 3 years old I wanted to replace it in case of any UV deterioration.
muzzaman
22 May 2008
If anyone can tell me the name of the lashing in the picture that would be great. I have searched already but no joy yet!
Many thanks.
lustyd
27 Jul 2010
It's just a load of half hitches around the looped cord, nothing complex. Get a piece of cors of 1m or so and tie it off to either the pushpit or the wire loop. Next, make several loops going through both - this gives you a bit of leverage to tighten very much like using blocks. Then wrap the cord around the loops and tie a half hitch. Do this until you run out of cord or reach the end then cut and tidy.
Cheers
Dave
estarzinger
23 Aug 2009
www.bethandevans.com
here are some instructions for a little more sophisticated lashing.
Its best if you either sew or tape the end of the tail to the main lashing, so it does not have any tendency to loosen/unwrap.
Adamastor
8 May 2006
+44 Country
My 2d-worth is to use red braid-on-braid line for the lashing- it deteriorates fastest in the sun and when it discolours it's a good time to replace. The jacket degrades well before the core, which is the most important part anyway... It won't lose any strength as the cover degrades, because the load-carrying parts are buried under the locking-hitches anyway...
wklein
28 Sep 2010
Dartmouth, Devon
Caterpillar knot
I always knew it as a caterpillar knot, You have a choice when you do it of changing direction after every pass so that the knots line up or you can keep going around so that the knots circle the lashings. Definitely worth doing the caterpillar knot though.
westhinder
15 Feb 2003
Belgium
I plan to use SS pelican hooks instead of line with the ring sliding over the hook under pressure so can'y be undone accidently :
http://www.amazon.com/inch-PELICAN-HOOK-Stainless-Steel/dp/B000Y85NPU
The surveyor who checked my new boat was squarely against lashing the guardrail. In fact he questioned the wisdom and the safety of working on a sidedeck in what are likely to be very difficult circumstances without effective guardrails. No point in losing more people over the side.
Worth a thought imho.
Twister_Ken
31 May 2001
'ang on a mo, I'll just take some bearings
How, then, did he propose rolling an MOB back aboard?
onesea
28 Oct 2011
Solent based..
Agree also take your 3mm line braking strain 150kg or 4mm Line 320kg give or take... Wrap it through so you have 6+ Strands supporting it= 900kg or 1920 kg Breaking strain?
I think something else would break before your little bit of line? Seems over the top to me.
I would consider fitting Senthouse slips/ Pelican hooks or similar as very useful to be able to drop rails to lift gear bags etc onboard. Just need to make sure they are not going to come undone when you do not want them to: mousing, lashing, tape, cable tie, elastic loop, etc.
alahol2
22 Apr 2004
Portchester, Solent
www.troppo.co.uk
When lashing up the guardwires I always put a few half-hitches partway through tying the whole knot. That way, if one strand should get cut through, the whole knot doesn't unravel in one go.
wklein
28 Sep 2010
Dartmouth, Devon
That pelican hook wont work
There is no way you could ever get the guardrail accurate enough to use this hook as there is no adjustment. I would always go with the lashings as rigging screws to tighten always age rapidly due to articulation issues.
You can get pelican hooks with adjustment but they would definitely need to be secured (presumably taping them would be only real solution). which makes the quick release appeal less appealing.
https://marineindustrial.co.uk/index.php/wire-ropes-rigging/sta-lok-guard-rail-fittings/sta-lok-pelican-hook-with-swage-stud-unf-thread.html
I also agree that the lashing is the strongest part of that system prob with pushpit / pulpit failing first, then wire, then lashing but if you make them too small they don't look right.
If your serious about getting MOB in in a hurry you could put gates in amidships but then thats a whole can of worms .......
flipper
8 Sep 2006
Cambridge, Boat Essex
I think this type is more secure:
http://www.amazon.com/inch-PELICAN-H.../dp/B000Y85NPU
D
Deleted member 36384
Yes there is a way. A small 10mm size bottle screw with forks terminals inserted between the guardrail wire and pull pit shackle. It is then adjusted to keep sufficient tension on the pelican Hook at the stern. Its a common method of tensioning guard rail wires. I don't think I have ever seen rapid ageing of a rigging screw.
You can get pelican hooks with adjustment but they would definitely need to be secured (presumably taping them would be only real solution). ....
Pelican Hooks are designed to stay shut when under tension. My liferaft is secured by a webbing strap attached to the deck with a Pelican Hook. This arrangement has never come undone, is a very common arrangement and in fact, due to the tension in the webbing it takes quite a bit of force to slide the lock ring over the end of the Pelican Hook.
I would agree if the guard rail wire is slack that the Pelican Hook could come undone quite easily, even accidentally, however, a shock cord loop would easily keep the Pelican Hook lock ring in the correct position.
..... If your serious about getting MOB in in a hurry you could put gates in amidships but then thats a whole can of worms .......
Why do you think gates are a can of worms. Just about all yachts I have sailed on have some form of gate in the guardrails. They all functioned well and didn't appear to be any hassle at all.
