Grrr - life ring lights
mobeydick
26 Sep 2005
They are made the wrong way up. The transparent cap screws OVER the 'base', which would be fine if they were stored cap-up. Stored cap-down, so the light is off, water sits in the thread of the cap, waiting to be sucked in, as described.
The cap should screw INTO the base, so water would run straight down and off.
MD
LadyInBed
2 Sep 2001
Me - Zumerzet Boat - Wareham
montymariner.co.uk
How about
ACR C-Light Lifejacket Light £11.26 but not a strobe, it "creates a twinkling effect" :)
or
ACR C-Strobe Lifejacket Light £23.95
I have two similar to this
Xenec Strobe but I didn't pay £30.59 for them! I bought them at the chandlers on the quay at Lymington.
Plevier
22 Aug 2008
Brighton
The Sirius still seems to have a screwy dome, which must be where moisture gets in.
Yes it does, but it looks a better job with a finer thread, it's factory assembled - maybe sealed with something, not sure other than an O ring you can see - and you don't have to disturb it because it has a 5 year (minimum; lithium normally lasts more like 10 years if not discharged) battery in it, and because it's not a gravity switch you can mount it right way up so water isn't lodging in the end of the thread and creeping in.
I reckon it's a much better bet, but only time will tell.
On reflection, I wonder if the water sensing circuit takes a tiny current all the time? I guess it must. Maybe that determines the 5 year life that they claim.
Plevier
22 Aug 2008
Brighton
Update on an old thread.
Yesterday I discovered my Sirius light did not work. (It did a few months ago.) It's 5 1/2 years old now, outside the 5 year claimed life.
I don't know why it has failed, but the point relevant to this thread is that I've unscrewed the "screwy dome" - with difficulty, very tight indeed - and there is absolutely no trace of water inside! I can't do anything to service it, the whole thing is foam filled, can only access by sawing it open which I will do for curiosity.
When it worked it was a very impressive flashing light.
I may well replace with the same.
Here's the working bit of it
Had 2 CR123 batteries under the PCB, both very flat.
Mandarin331
27 Oct 2008
North Norfolk
mobeydick
26 Sep 2005
You see that component ICIB? That is a timer that counts down 5 years and 6 months....
MD
Topcat47
2 Jun 2005
Solent, UK
I manage to keep water out of my Lazilas lights for about five years or so using Fernox LSX on the threads. Eventually the crappy electrical connector corrodes and the whole thing stops working. There's no point putting a sachet of silica gel in either as it stops the lamp working,
