PabloPicasso
With sandpaper or wet n dry is the lower number coarser? i.e. 40 grit is rougher than 60?
Think of it as the number of grains per inch. So the bigger the grains, the fewer there are and so the coarser the paper!With sandpaper or wet n dry is the lower number coarser? i.e. 40 grit is rougher than 60?
The number is the number of holes per square inch.
Great stuff! :encouragement: Now I know something I didn't know I didn't know!
I knew which way the numbering went, but I didn't know why, or that it related to anything in particular. I've got a specialist repair job to tackle that involves working out the coarseness of some existing (embedded) grit, and this info will help me solve the problem.
Sounds interesting, what is it?
I'm in a nosey mood![]()
(it's something black or grey that sparkles when it catches the light, if anyone has any suggestions)
I would guess it might be carborundum, the grit used on wet and dry paper. That can look black, dark grey and slightly reflective. Small quantities can be purchased on ebay in the lapidary section as it is used for tumble stone polishing.
