Nick_H
Has anyone come up with a better solution for grey water than the normal small accumulator box, with an integral bilge pump and float switch to expel the water out through a sea cock via a non return valve.
Ours regularly gets blocked up with hair, and is an unpleasant job to clean, plus i've had to replace all the components at least once.
I was thinking maybe an external diaphragm pump would be better which would just suck the hair out, or maybe an easy access mesh filter on the inlet, although neither of these solves the unreliability of the parts problem, especially the float switch.
Best option would be a ready made complete system so I could just chuck out the current tank and replace it with something more robust and/or easier to clean. Does such a thing exist? I'm not really constrained by space as it's alone is a fairly big section of the hull.
