icepatrol
my teak decking is grey in colour. is this normal and healthy for the wood ?
can it be left like that and last or does it need treatment ?
You can restore it to golden, as new condition, with lots of chemicals or elbow grease. Every time you do this advances by quite a lot the day you will have to replace the whole shebang.
Grey is the natural oxidised colour, and boldly showing it on your boat shows you have moved on to more worthwhile uses of your time, such as sailing...
PWG
PWG
You don't need to walk on things outside for them to get dirty. Atmospherically borne dirt, pollution etc all gets into the surface of the wood. Perhaps there is a natural reaction with the oils of the teak? The sheltered bits of wood that snooks referred to don't get rained and showered by the dirt that the exposed bits get.I have some leftover bits of teak that I've left outside for the last two years or so. They are now greyish in colour and nobody has walked on them. I believe this is the natural colour of teak when exposed to the elements.
For whoever said that every time you wash the wood down with chemical cleaner, you hasten very quickly the day that you have to replace it, is talking baloney. Sanding it and scrubbing it hard with a stiff brush, pressure washing it, and abusing it hastens the day you have to replace it, but I don't believe that oxalic acid or the two part chemical process takes anything off the teak at all except the dirt.
John, it would be good to prove what you say, but logic would seem to say that if you suddenly have bright looking teak again after the application of a chemical such as oxalic acid, surely that must mean that a new layer of wood fibre is exposed. The old wood cannot suddenly become new looking again. So application of oxalic acid wood appear to remove surface fibres of wood.
Interesting, not seen that suggestion before.
Would the oxalic acid attack the SS stanchion bases at all, or does a rapid rinse down prevent any problems like that ?
Oxalic acid can be used safely around all fittings. A mate who used to work on superyachts introduced me to it, and I don't believe they would take risks with their deck furniture...Although I did hear of the new lad cleaning the ships acrylic windows with jif!
If you think of it as a bleach rather than an acid, it sounds far less scary
Here's a link with a bit more info
IIRC the oxalic acid bleaches the dirt and grime that's trapped in the grain. For example similar in the way that peroxide bleaches the pigment from hair.
So are you saying you just mix the oxalic acid, coat and then wash off as the instructions just ignoring the final paragraph about sanding the raised grain?
