Grease Gun
shaunb
Active Member
15 Apr 2006
Cardiff, Wales, UK
Hi
Any advice on which grease gun to fit on a 26 foot yacht? Checking my stern tube, there is a grease nipple on it, but no greasing system. I have seen the type before that is permanently fitted with a twist top that you put a couple of turns on every time you go out. Any ideas on make/ model? I cant seem to find anything.
Cheers
go to your local bearing/powertrain supplier, if you can take the existing nipple with you. thet should be able to match the thread (metric or imperial). they may suggest an ordinary grease gun, or a remote mounted line, if that's easier.
there is a make called LASER which offers a small lever action grease gun which will also take a flexible tube about 15 inches which is handly when access is limited. Sold at many auto factors.
also range of grease guns on amazon.co.uk
Here
"Artificial intelligence is no match for natural stupidity"
sailroom <span style="color:red">The place to auction your previously loved boatie bits</span>
Thankyou Lakesailor, I will be fitting one of those over the winter (as soon as I know what size I need) and I will be happy to throw away the old pump greaser that rattles round my bilges at present. At that price (even allowing for VAT, P&P and phone bill) who could resist. I just hope they don't run out (or add a zero to the price) after 200 calls from forumites.
I thought he was looking for a pressure greaser not a gravity oiler. /forums/images/graemlins/blush.gif
The clue was in the question. /forums/images/graemlins/wink.gif[ QUOTE ]
[/ QUOTE ]Which was what I gave the link to..... /forums/images/graemlins/smirk.gif
Not really, the present one is an oil bath (halyard) type. /forums/images/graemlins/grin.gif
the type you posted, is it auto i.e. spring driven to keep a constant flow?
I had totally forgotten about the reservoirs that lakey posted and might pick up a pair.
I made a mistake and bought one of those cartridge type guns, thinking it would be easy enough to refil by hand, it isn't. Although the cartridges don't break the bank I don't want to be tied to them.
It is a right pain having two stern tubes 12ft apart in different boats and they are under the sleeping cabins, I hate taking the grease gun in there as I am afraid of marking the bedding or white carpet (walls).
I guess the link you gave (cliff) would mean the greasers could be remote which is appealing. shame I would need two though /forums/images/graemlins/frown.gif
My other fear would be extracting the old nipple, it holds the same fear as trying to slacken a brake bleeder on an old car, nnnngh snAP!
[/ QUOTE ]No, Manual by turning the handle.
What about running two lines from your stern seals to somewhere convenient and fitting remote grease nipples. Have a look at some excavators - the pin joints are sometimes greased by this method.
Theres a bit of diff between the "grease gun" arrangement required in the question to a gravity oil feeder! Cant find the clue, perhaps it me.
