Robin
Trying to replace a faulty GPS aerial last weekend I connected the new one to test it and moved it around to find the best location to fit it. (for some reason the replacement from Raymarine has only 10m of cable, it's predecessor had 15m). It actually worked quite well according to the signal strength display down at the chart table, but close to the VHF etc and I know this has caused interference for some people fitting the ne NASA DSC set, so I thought I would try ours (an old Midland 5600). Well 10secs at 25w transmit, I didn't try 1W, and all the satellite signals vanished. OK so the aerial was too close to the VHF set down below, so I moved it outside and tried all over, even where it would normally go on the gantry at the stern. Guess what? 10 secs of transmit = no signal! OK so now I'm in experimental mode, tried the original aerial still on the gantry (it usually works for about an hour before going AWOL) and same result. OK so how about our #2 set, Navman Plotter with built in WAAS GPS this plugs in out on the coachroof, yes this also loses the fix after 10 secs on transmit! So 3 different GPS's in 3 locations all affected. All signals return when transmission stops and a fix quickly found again.
The VHF works fine as far as I can tell, we receive and transmit over long distances without problems (ie Cherbourg to Portland CG).
This is now getting worrying. We have never noticed a problem in practice, so maybe never transmitted long enough in one spurt to actually lose a fix totally (takes probably 30 secs of no signal before the 'no fix alarm' goes. The VHF aerial is masthead mounted and 50ft above deck, the lead runs under the deckhead lining. There could not be more separation between VHF and GPS aerials without buying a bigger boat.
Now if we replace our VHF with shiny new DSC one, it will transmit our position in an emergency, obtaining said position from the GPS - except that if it transmits for more than 10 secs it will probably knock out the GPS signal......
So what now?????
So what now?????
