Going forward in a blow
Spacewaist
1 Oct 2002
UK
blog.mailasail.com
To weather - and if Ive got loose stitching on my harness I buy another - or use someone else's. Its my life we're dealing with.
LOOK OUT!!! Behind y.......! Five more hoots and you're history!
sailbadthesinner
3 May 2002
Midlands
you can get them restitched professionally i am sure. but as you say it is your life so pay for new one and get it double stitched!
donot forget to check jackstays
altho a few of the losses in sydney to hobart appeared to be failing harnesses so there is a lesson there. who has checked their's recently.
Come on brain.get this over and i can go back to killing you with beer
dickh
8 Feb 2002
Suffolk
Definately on the windward side - much easier and you can see what you are doing without struggling past sails etc.
I have always checked my harnesses each winter and washed them in fresh water as well.
Jackstays - I have webbing ones but intend to replace them this winter as I don't know the strength of the original, they have certainly faded a lot - I suspect they are about 10 yrs old. After I have got my new ones, with snapshackles, so I can easily remove them to avoid UV degradation, I will get the old ones tested to destruction to see where and how they failed and will post the results on the forum.
dickh
I'd rather be sailing... :)
claymore
18 Jun 2001
In the far North
Uphill or downhill - one therefore has to assume that one is going upwind in this blow. Now why on earth would one want to be doing that?
regards
Claymore
petery
9 Jul 2002
Boat in Redon, France
Harness and halyard ?
Having read this thread over the past couple of days, I poked my head out of the harbour to try my new storm staysail yesterday - and it got jammed and I had to go forward!
It struck me that if I wore my harness clipped on to the jack stay and also clipped on the halyard I use for the cruising chute - suitably cleated off - I would have the best of both worlds going forward.
I didn't try it because I thought there might be snags that I had not thought of - any comments or advice?
kds
21 Nov 2002
Somerset
www.canongrange.co.uk
Uffa Fox solved the problem years ago - The Fairey Atalanta was designed so that you never needed to go on deck. Everything at the mast could be handled from the main hatch and everything at the forestay from the fore-hatch. The bows were so bouyant that this is possible in even the most intimidating seas. Does get a bit damp below - but it does anyway, doesn't it ?
Check out some pictures of my boat at;
[link]www.canongrange.co.uk/boat/[link]
Re: Lost the plot!
Jimi writes
> although in reality if you're well heeled and a bit of a sea running you'd probably heave to first.
If you are really well heeled then get the paid crew to do all the hard work. :)
Regards
Fred
Just because you're paranoid doesn't mean they aren't out to get you.
