Godwins candidates
zoidberg
12 Nov 2016
Another small point but of occasional significance to some....
.... of those who wear drysuits.
When donning, after the zips have been done up, squat down completely and let the air so compressed escape out the neck seal. Otherwise, when put to the test, air trapped inside the suit collects around one's lower legs which consequently float higher than said head.
The struggles to get a breath can last, it is said, for several minutes......
fisherman
2 Dec 2005
Far S. Cornwall
One of our lads did a survival test this summer when he sank. He's a big lad, 22st and 6ft+. The (correctly fitted) LJ formed a large cleavage in front of his face, which filled with water with every wave that sloshed over him, he was blowing it clear all the time.
KeelsonGraham
6 Jul 2021
Hmm. I wonder if that LJ was sufficiently buoyant for him. Also, this underlines the importance of reaching back and pulling the sprayhood over your face.
justanothersailboat
2 Aug 2021
I wish there were fewer models of lifejacket with one crotch strap and more with two, carefully positioned either side like a modern climbing harness so that no sensitive areas are imperilled. Not for when floating, but for when clambering about the deck and/or when clipped on. I have perfectly good LJs apart from this problem, bought before I realised why I would really like the other kind.
KevinV
12 Oct 2021
I prefer a single strap, I tend to get hamstrung by two straps falling under my legs when sitting, then not rising when I stand up.
I don't understand the fuss made by those who would rather drown than have sore goolies.
Daydream believer
6 Oct 2012
Southminster, essex
If it was the choice between becoming a transvestite or drowning ........:(
Worse still, becoming one--. Then drowning. :rolleyes:
zoidberg
12 Nov 2016
jimi
19 Dec 2001
St Neots
For appendages being crushed beyond all useful purpose you really need to wear the Whillans Sit Harness for several hours on a very small ledge on a bitter cold night on Ben Nevis as 'Fred' who is leading works out the crux on Point 5 gully well after his headlamp, powered by four D cell batteries, has given up shedding any light despite being stuffed inside his string vest.
Mountaineers of a certain age will understand.
I had one and its major disadvantage was flipping you upside down if you fell off. It’s predecessor, an early yellow troll harness was known by us as the ba crusher..
