Go faster stripe, apply or hand paint
pcatterall
2 Aug 2004
Just below the bulwark on my Neptunian is a moulded in feature ( a long stripe with a bit of Neptunes trident at the end !) it has been ( badly) hand painted red and needs redoing.
The stripe itself is about 12mm wide. Before I get out the paint pot and masking tape I wondered if a go faster stripe would be available and would last in a marine environment.
I could cut it to suit neptunes prongs. Perhaps there is a marine version for sale ( at 5 times the car shop price!)
Any ideas/advice/contacts
Many thanks
Avocet
3 Jun 2001
Cumbria
Avocet has a very similar stripe - almost semi-circular in profile. I have always painted it - taking the view that it is probably easier to get the masking tape straight (as you can re-position it easily) than it would be to get a vinyl stripe straight - especially pushing it into a hollow. That said, I've never tried vinyl!
Also, does the profile of your stripe change at the ends? Avocet's broadens out somewhat. I don't know how you'd do that with vinyl.
sarabande
6 May 2005
it's called a cove ,or sometimes, a cave line. I suspect that the irregularities in the surface will make it difficult to provide proper adhesion to a vinyl line, so it's either paint, or size it and fill in with gold leaf. :)
Csail of this forum has some clever machines which cut emblems to complicated shapes.
pcatterall
2 Aug 2004
Thanks guys. I have located a good site for stripes but Avocet makes a good point, if I can get the stripe on straight then I can mask and paint just as well. There is a shape at each end ( the trident) which will be better in paint than trying to cut bits of the stripe.
I think I'll give the paint job a try. Gilding is parhaps a bit OTT for now!!
rob2
23 Aug 2005
Hampshire UK
My boat has a light blue stripe along the gunwhales which appears to have been sprayed on with cellulose paint when new. The cove line is white and has always been hand painted. I repainted the line with acrylic paint from a car factors. It needed to be thinned quite a lot, but looks quite good, and ,of course, the class insignia at the bow is easier to hand paint than cobble together with tape.
My only worries concern how I will repaint the blue as it has faded over the years and cutting is starting to show through to the undercoat! Does anyone know what paint would be suitable?
Rob.
vyv_cox
France, sailing Aegean Sea.
coxeng.co.uk
I've heard it referred to as a "cavetta" line before. Is that a real word?
Yes, it's spelt Cavita.
I have a red and blue line on each side, done in tape. I replaced them both last season, buying the tapes from one of the companies advertised in PBO. Putting them on straight is a much harder job than it would appear. The tape is quite elastic and it's easy to overdo the stretch. I skimped a bit on marking the lines up with pencil before starting as I could see the marks made by the previous tape. I soon realised that this was a mistake as they were not very visible when doing the job, and I started again. Eventually I got them reasonable but it took far longer than I expected.
