Gludy
Thank You.
I can confirm that as true and St Francis Marine stated this was not a problem.But it would appear that Paul specified that the halyard and reefing / furling line for the Leisurefurl mainsail should be led aft, so that the helmsperson and crew could control these activities from the cockpit.
I think that this is probably the first dodger that has been been built with ‘solid’ windows – the boats shown on the St Francis webpage all appear to have simple bimini canopies with no solid screens.
This set up with the Leisurefurl system was a prototype (for SFM) arrangement – it was the first time (as far as I know) that SFM had ever led control lines from the mast aft to the helm station.
They are not functional and display a total lack of understanding of basic rigging principles. They could have been run far better at the time.And I think that we are all in agreement here that the various turning blocks and rollers shown in the photos at the beginning of this thread were far from perfect at this initial stage, and needed further development!
Changing tack slightly now, after seeing the rather unique and innovative davits** that were designed and developed by SFM for Suliere’s tender, and realizing what they are capable of, I am sure that if further development work had been undertaken by the yard then on the various fittings for guiding the control lines aft to the helm station, a very workable system would have evolved, if time and trials had permitted.
These repairs appeared (to me) to be certainly strong enough for lifting the tender in its lightship condition (ie with no water ballast or passengers on board) in normal circumstances.
However SFM apparently gave Paul a full refund on the initial purchase cost of these davits, which he then applied towards the (greater) cost of Grenada Marine fabricating a new pair to the same design but with thicker wall section on the S/S tubes.
I was new to the sailing bit and trusted Duncan the expert sailor on it. He altered the system after sea trails and we trailed them again until he was happy. It made a hell of a noise but I thought that was normal for this syetm - I was wrong.Going back to the Leisurefurl system - re the development trials of the prototype control system devised for the Leisurefurl, these should have (in my humble opinion) included various (ie comprehensive) tests of both the roller reefing genoa and the mainsail, ideally in a variety of conditions, and they should have also included testing the other sails as well.
Paul, by departing from St Francis Bay with Suliere when you did, does this mean that you personally were totally happy with every aspect of the vessel’s hull, rig, sails, machinery and electrical / electronic systems?
I ask this without malice, it is an innocent question.
If yes, did you and Duncan compile a detailed check list of items to go through prior to acceptance, and was this list ‘signed off’ by both the Owner and the Builder to indicate agreement? I get the impression that this did not happen, otherwise it would surely have been mentioned before.
Duncan has totally fabricated that - we refused to leave without very point being checked. he controlled the sea trials and told us we had to set off sometime we could not stay there forever and that normally the final shake down to Cape Town was it - withheld a large sum until after the work in Cape Town. You are quoting a total fabrication that is a smoke screen for what is basically a very simple reefing problem.Duncan has mentioned in his Facts or Fiction post in the Dispute thread on Paul’s Multihulls Forum that “Sea trials were never completed to the mutual satisfaction of Builders and Owners (which is the usual procedure), due to the Owner’s desire to leave for the Caribbean as soon as possible”.
If not, why not??? I know that you have pointed out that the vessel was 5 months late on the initially agreed delivery date, and that you were apparently in a hurry to get to Grenada (I am sure that you yourself mentioned this somewhere as well), but surely it would have been possible to add on an extra few days or even a week at St Francis Marine to make absolutely certain that all systems were working properly prior to sailing (or motoring rather) the 2 day passage to Cape Town (and then onwards to the Caribbean)?
The main bone of contention now seems to be the issue of the pulleys / sheaves / turning blocks and rollers guiding the main and jib sheets, mainsail halyard and reefing lines aft to the winches in the cockpit.
I understand that following initial complaints re how the rollers were butting on to the winches, SFM supplied Paul with new rollers, some new sheaves (?) and new winch drums, with instructions for fitting by the yard in Grenada.
The rollers were then subsequently raised by 6 mm as they were apparently still butting on the winch drums, but it sounds as if this modification was not very successful.
Paul has mentioned above re how he is now having much more substantial S/S base plates made up for supporting the rollers, as the fibreglass structure under the roller assembly was apparently deforming noticeably when under load.
An appreciation of the complexity of this vessel can be gained from the purchase costs of Suliere (which are not confidential – they were posted on Paul’s Forum) – the basic boat cost approx US$ 800,000, while all of the ‘extras’ amounted to approx US$ 550,000. I would hazard a guess that if the same design was built by a reputable yard in Britain to a similar specification, the final cost would probably be at least 50% more.
I am sure that SFM have certainly learnt a lot from building Suliere – and I very much doubt that they will allow any future new builds to leave the yard until a full programme of sea trials has been carried out to the mutual satisfaction of all parties concerned, and these sea trials then ‘signed off’ as part of the contract / agreement.
In conclusion, I was of the impression after visiting Suliere at Grenada Marine that the overall quality of construction and outfit was generally very good indeed (apart from the last few problems still remaining to be sorted, as detailed above and on Paul’s Forum) - Paul has said this as well, and I am sure that most readers on this Forum will agree with us on this if they do get the chance to visit Suliere and cadge a beer off Paul!
And I will offer a polite suggestion here to SFM that for future orders they should positively encourage new Owners to appoint their own representatives to oversee the building project (especially if the Owners do not really feel capable of overseeing it themselves), as this will ultimately be for the mutual benefit, health (re blood pressure and stress!) and protection of both Owner and Builder.
Paul, you have been very selective here (as usual!) re the information you have disclosed regarding the running rigging problems on Suliere.
can you just confirm - you were paid by st francis marine, and thus are just a teensy bit compromised here, right?
Yesod – replying to post 88 above : - Yes, we were paid by St Francis Marine for the inspections we carried out on Suliere last year.
But that was all; we have not had any further business dealings with them since, and I am not anticipating receiving any more survey commissions from them re Suliere.
If they do ask us for any reason to visit Suliere again when she is laid up in Grenada for the summer (or in any other island for that matter) I would politely decline, as I believe that Paul’s surveyor there, Bob Goodchild, is extremely knowledgeable, experienced and impartial, and I would have complete faith in his findings, and I would suggest to SFM that they should too.
Edit - after reading Paul's note above - as you can see from the above, there is no 'client' involved here.
aul – Re my post yesterday on your Forum, that was more concerned with the whole issue of claimed delamination of your hulls.
The bottom line was that there was no evidence as such at the time of our inspection of any delamination of the foam cores in your hulls.
But you still do not seem to accept that.
I had hazarded a guess above that Suliere was probably the first SFM 50 to have control lines led aft, and Paul corrected me - thank you.
You mentioned that Bamboo was also fitted with a fixed windscreen – how were their jib and mainsail sheets (and halyard and reefing lines as well?) arranged?
Did they have a similar set up to Suliere (where the winches are mounted on the sloping aft side of the cabin, with rollers to guide the ropes over the corner), or did they have some other system?
This is a genuine question, and I am very interested in how their system works.
You can swing a full sized winch handles on the port winch and a short winch handle on the starboard winch. I insisted St Francis make the short handle one because its always best to finish off manually.The fixed windscreen under the bimini awning has many advantages – however one disadvantage is that there then is not enough room to swing a winch handle if the winches are mounted on the outboard sides of the cabin top, which seems to be the usual arrangement on the vessels with bimini roofs and no windscreens.
But after the first sea trail corrections they were not improved - Duncan was happy with it. That is the whole point.Re the leads to the winches for your reefing line, halyard and sheets, I agreed that they needed to be improved.
If the angles were not correct when you carried out sea trials and took delivery of the boat they should have been seen and corrected then.
Re you being selective in what you post, I said this simply because you launched immediately (with your original post) into the items you were complaining about, with no background information to enable readers to see the ‘whole picture’.
I thought that it was very difficult for anybody not familiar with the vessel to visualize this whole picture just based on the photos and information you had provided, hence why I posted a variety of photos to illustrate the whole system.
If I was going to make a complaint of this nature, I would lead up to it with an introduction – in this introduction I would try to look at it through the eyes of somebody who has never seen the boat before.
The only reason for mentioning the davits was to suggest that SFM appeared to be very good at lateral thinking and coming up with new ideas to solve problems, hence based on this apparent ability I was of the opinion that it should have been possible for them to further refine the prototype arrangement that was installed for the Leisurefurl system if you were not happy with it.
I totally agree with all of that. But it really would cost money to correct and I guess Duncan was not keen on that - i was ignorant on it
I thought there was no choice but the high noise and racket - I was a novice and had the wool pulled over my eyes at a time when i had total trust in Duncan. However there you go again instead of addressing yourself to the terrible system that no experienced sailor could have devised, you try to swing responsibility on me.was not trying to blame you for this Paul – you say that Duncan was happy, with it, but surely the bottom line here is that you yourself should have been happy with it?
When we reached Grenada the sheaves the new drums and the lifting 6mm were all offered as a cure when in fact they just addressed the symptoms.Was any explanation offered at the time for the noises (graunching?) experienced while the system was in use?
Re the cost going way over your initial budget, had you specified all of the extras at the time that the contract was signed, or were some of them added on later?
I only mentioned cost of boat and extras to illustrate to readers here that this is a very complex boat.
And I think you would agree that one of the attractions of South Africa for boat building is that the cost of their overheads including labour is considerably less than (say) in Britain, and that this would be reflected in the quoted cost for a yacht which should be very competitive on price when compared to a similar vessel built in Britain.
being in the business it is your right to claim that but in practice that was not really easily possible in St Francis. In any case it does not change the fact that the builder is responsible for their work.I will be the first to agree though that the reputation for quality assurance by South African builders in recent years is generally poorer than their competitors in Britain, hence why I would always insist on having outside supervision / surveys during the course of construction if I had commissioned a boat built there.
In fact I would do the same in Britain (or anywhere else in the world) if I was buying a boat for US$ 1.35 million.
Exactly.Rather, it then simply comes down to why or how the thing failed later on while in service.
I am not expecting any support on this point as it probably affects many who might be reading it.
How to determine end user competance is not the job of the boat builder. We trust that every owner will take it upon themselves to learn to care for their boat in a reasonable way. If the owner of the boat is seriously lacking in knowledge and expertise there is a massive amount that can and does go wrong. How does a novice recognise for example when a winch is over loading ? If you don’t know what you are doing, all too often by the time you realise something is wrong, its also broken. Yet the yard must just believe whatever the owner says. Would Mercedes Benz be happy with any warranty claim if the driver of the vehicle was an unlicensed learner?
A day skipper sail is in no way or form qualified to be sailing a 50ft catamaran between the islands in the West Indies.
I wonder what controls exist through the RYA or maritime law to keep unlicensed users in check. It is no doubt a very difficult situation to police. I believe no matter what, an applicable qualification has huge relevance in how a vessel is looked after.
Paul, your passion lies in the “internet scrap”. The current topic is sailing catamarans.
You have owned one for 18 months and yet you have not managed to find the time to qualify yourself to drive it. You attempt to come across as squeeky clean Paul but if you had an accident under sail, you may well find yourself in very deep water.
Duncan
I agree with that, Av experienced sailor would have known the rigging for the mainsail was terrible. Had I had even with the experience I now have I would have spotted it.What lets you down is that your level of experience is quite clear. A truly experienced sailor might possibly have spotted these faults on a walk around.
Duncan actually scoured the winch in trials and did make one change but it did not deal with the underlying issue just the symptom. He must have known how bad it really was. Again that makes the builder even more responsible.The major point is that he would certainly have spotted it when operating it. He'd know that the load he was applying did not equate with what was happening. He'd stop. Look and find an alternative with bits of string, spare shackles to make it work, and sail happily back to the yard, after that trial.
No not me - other problems were dangerous and life threatening.You have implied that a badly arranged mainsail reefing system is life-threatening. Er. No. It's not.
You must have known (from prior experience) that boat building is not a science. And yet you signed up to spend a vast amount of money without professional oversight?
You took a boat across an Ocean without the experience to know that a reefing system didn't work properly?
Taking a dinghy sailing course would cost you a fraction of the cost of that computer you're sitting at.
spent a long time in the boat making business, and did a degree in Naval Architecture.
Now let me ask you a few things.
Was part of your training learning how to not be responsible for how you build boats?
Don't be silly. No.
Did the training include learning how to wash your hands of your failings and how to swing the blame for those failings onto the customer?
Don't be silly. No.
Would you not agree that the rigging is a flawed design that no boat builder should be proud of?
'Rigging' is too vague. The way that the lines are dealt with at the helm? Awful.
Should an overseer have spotted it? Yes. Absolutely.
Please answer those questions because frankly your attitude belongs to a few centuries ago. As such it is a disservice to the parts of the boating industry that do actually try to have some standards.
If you answer those questions I am happy to continue to discuss these matters with you.
