DownWest
If you have a ridge, then conventional wisdom says, 'Rebore or resleeve'. In my distant past , I did several 'rough' rebuilds, deglazed with a 'small cylinder hone' (actually designed for brake cylinders, with only two stones) And always fitted STEPPED top rings, mostly from AE. As they were much less than the manfacturers brands. 'Perfect circle' in the USA seem to be a current equivalent. The explanation about wear on the top rings matching the bore is logical. Leading to new rings being stopped short on the old ridge. Certainly it was current then. Depending on the thickness of the liner (cylinder) sleeving might be an answer. But I doubt that it is cost effective compared with a new one.
If you can get stepped top rings,use them. Eliminates one possible problem.
Sealing in the bores is more inportant on diesels than petrol donks, so getting it right is prima.
Replacing the engine (price) might focus on getting this right.
A
A
