gordmac
If you have a significant lip at the top of the bore (feel with your fingernail) I would suggest it is too worn and change the liner although you may be ok with a hone and a stepped ring. Ideally you should measure the bore in several places, at 90deg in maybe 3 heights. You used to be able to get a tool to remove the step (Eastwood tool company?). The hone pictured is the tool for the job but (herisey I know!) I used to do it by hand with emery paper.
Make sure you clean all the grit out though.
You will need to gap the rings correctly, too tight and they break, too loose and you lose a (small)bit of power and burn a little bit oil. Similarly if you don't de-glaze you might use oil and drop power. I used to use a particular procedure to bed the rings in (car), not so easy with a boat maybe but it does need to work a bit rather than tick over.
