gibb
bige
6 Mar 2002
i have a saddler 25 with gibb winches and i need to replace the nylon ? inserts as they have worn and cant find a supplier for gibb or a service kit supplier.the winches tend to rock side to side,any advice would be very welcome big e.
aitchw
18 Feb 2002
West Yorkshire, UK
I would contact a local engineering machine shop with a view to having several replacements machined up.
The inserts could well be a nylon and I am assuming you are able to dismantle and remove the worn ones. With these in hand and a diameter for the shaft that turns inside them any machine shop could make them.
Cheers.
Howard
ccscott49
7 Sep 2001
If you get some made up, consider making the new ones from bronze, last ages.
I am replacing my ibb winches, because I could not get spares anymore. The inserts are bronze and in good order. I have a 24' (7.25 m) boat and the winches are comparable to Lewmar 8 in size. If that suits you, make me an offer.
wiard@orange.net
Chris_Stannard
11 Jan 2002
Cowes. Isle of Wight
I am told that most manufacturers use commom bits, but I don't know how true that is. Suggest you look at Lewmar and other spares kits to see if any are compatible before adoopting extreme measures
Chris Stannard
They don't. I have searched high and low for Gibb spares.
