Spi D
Not good. Depending on the fault code shown it regards something in the engine electrical system.
You mentioned your engine, so we now know that you are running a single Volvo D3-190. This 5-cyl 2.4 litre engine develops 180 hp @ 4000 rpm on the propshaft and the recommended rpm range at WOT is 3800-4100, so your aim with normal load is the 4100.
The engine was delivered with either single prop SX-M1, Duo-prop DP-S or XDP-B sterndrive and gear ratio inside is 1.51, 1.66, 1.95 or 2.11 so you will have one of these.
