johnchristie
Active Member
I've seen a few posts which talk about getting the boat on the plane for optimal performance, both speed and fuel economy.
the posts suggest to get on the plane you tuck the drive legs in using the power trim to bring the bow down and by doing this it uses the V of the hull to cut through the water and then you trim out as you pick up speed which raises the bow.
Is that correct because when I tried it in the solent today after my PB2 course (albeit it was choppy) I noticed the revs dropped when I trimmed out from -2 to +2 and the only way to maintain speed was to leave it on 0
We didn't really change the power trim on the instructors boat, he just had the trim set to +2 which raised the bow.
