Davy_S
Not wishing to spoil a thread that was posed on Mobo recently. If you had a small Mobo or yacht and no wind and your engine had broken down, you are a few miles from land. Ok, it could be possible to use a small outboard motor off your dinghy to get you home. If you had a small generator, would it be possible to plug an electric motor into it and fasten a small shaft with prop over the side. Or would a small outboard provide just as much thrust? Say a 2kw genny coupled to a wasing machine motor with a means of welding a shaft and prop to it, then having a means of attaching it to the transom, would it work, or should I go and lie down
