shan
Has anyone fitted a generator into a Rodman 1250?
I saw one I place of the fish box by the door.Has anyone fitted a generator into a Rodman 1250?
Photos would be really useful please.Not the same boat but another Rodman, a 38 - my Paguro gennie is at the back of the lazarette next to the port fresh water tank.
It is sitting on a plywood shelf glassed in as per other large fixtures in the boat. The exhaust goes into a water cooled silencer below the gennie and out the transom a few inches above the waterline. Battery power comes from the port main batteries. I am pretty sure mine was fitted by Rodman. If you want I can take a few pics so you can see how they did it.
I am at the boat on Wednesday, I will try and take some pics for you.Photos would be really useful please.
Thank you.I am at the boat on Wednesday, I will try and take some pics for you.
The noise reduction is great at anchor.Thanks. Could be a useful space saving option.
Yes, I'm sure it is! The generator would mostly be used for air conditioning - very necessary and mostly running when at anchor.The noise reduction is great at anchor.
K, would you care to explain to the panel why you have a garden hose attachment on your generator ?Some pics of my generator installation - and yes that really is a hose pipe connection! It's a temporary thing.
the generator sits on a glassed in plywood shelf.
exhaust silencer and seacock etc
Water trap/anti syphon, then the exhaust goes out the transom
Now... now... retract those claws......I'm sure he wouldn't like to explain. Anyway, his wife has probably already asked.K, would you care to explain to the panel why you have a garden hose attachment on your generator ?![]()
In my experience garden hose connections are prone to failure except for Gardena. They are a good brandThe hose pipe connector is there so that I can plug a hose pipe with fresh water into the cooling system and rinse out any salt water before I leave it for long periods.
The cooling system on the single cyclinder engine is a bit carp and easily blocks with rust etc. I pretty much never use my generator so I leave the sea cock closed unless it is in use. I have been trying to find something a bit more suitable but to be honest the hose pipe coupling won't corrode and it is not under pressure. Any better ideas gratefully received.
