Bav34
Need help
I've looked at various web sites and they all seem a bit general ... for example ''use this wet and dry ... or that wet and dry'' ... but when do you change?
So.
I've taken the bits I understand and started to repair the 14 chips and scratches caused by someone doing a hit and run on my boat.
I masked up the repairs, applied gelcoat mixed a little 'harder' as it was only 12 degrees today ... then the first bit of confusion.
I put sellotape over 12 of the repairs (two were really small) and this seemed positive as it smoothed out the surface. I wondered at the time how could the gelcoat cure but assumed some sort of internal heat generation caused by the mixing of the hardener.
Four hours later the 2 that had been open to the elements were rock hard but when I pulled off the sellotape there was a very chemically smell and the surface was still tacky.
So, should I have put the sellotape on? If so, how does the repair cure?
I'm going down tomorrow to 'hopefully' find that the repairs have cured.
This moves me into wet and dry territory. The repairs are all proud of the hull by just the masking tape thickness... I'm actually quite pleased with the visual effect but if I start rubbing with say 240 when do i work through to say 1000? How do I stop the 240 affecting the surrounding surface ... or do the subsequent finer grades take care of that? If I use 1000, when do I stop??? Do I need a paste as a final step before polishing?
Incidentally I don't have a mechanical polisher ... just a hard block and a more flexible one.
Final question ... for some unknown reason I have a big tube of Farecla G3regular grade paste compond. Where does this fit in the scheme of things? Somewhere between 240 and 1000 or after 1000 ... or not at all?
As usual ... any help appreciated.
So.
