BigStu
Active Member
After a delay my ‘new’ Longbow is meant to go in the water tomorrow first thing for our hols.
However…. When I was reattaching the prop shaft to the clamp on the gearbox (after a stern gland service) I noticed in either gear the shaft could still turn in both directions (see other post) . In all the other boats I have had this should engage the engine and ‘lock’ the shaft (unless you can turn the engine). The engine is a Volvo Penta MD2030D with an MS2 Gearbox
I was surprised at this so had no choice but to have to run the engine up and see if she would turn the prop in Gear with the engine running. I know normally this would not be an ideal thing to do on the hard but I wanted to see what would happen. So only momentarily put her in gear.
Basically in either forward or reverse when ‘clicked’ into gear nothing happens. It then takes probably about half speed on the engine to make the prop turn. That would mean to creep forward you need about 2000 revs! If I power back down and leave in gear to the ‘notch’ it spins but I can easily stop the shaft with my hand. Also if I leave in gear and turn the engine off- I can turn the propellor with not a lot of effort the way it should be ‘locked’.
My feeling is this gearbox is shot as all of that in theory should not happen (I think). The cables are pushing the leaver all the way forward so it seems set up right. is this the classic worn clutch or cones symptoms?
The last thing I want is to drop her in and have a load hassle with the gearbox when I should be having a stress free holiday!!
I’ve got to make a call today whether to go ahead and get her in- but this sounds like trouble to me….
