Beadle
Turned on the hot water system on the boat the other day. Result was no water from taps - lots of water from somewhere inside the machine.
Examination showed that two of the water pipes had split. Almost certainly frost damage.
The splits are only small - each about 1/4 inch long.
Question is - is it possible to repair these splits, soldering I guess. If so I would appreciate any suggestions. Only other solution would be to buy a new heater at around £200! - and that would involve shifting all the pipework about - which I don't fancy much.
Any ideas much appreciated.
