Gas regulator
PabloPicasso
12 Feb 2010
Is there a special salt water corrosion resistant calor gas regulator? Or do we just replace the usual regulator more frequently?
Martin_J
19 Apr 2006
Portsmouth, UK
By 'often', I mean I've often recommended them to friends who have subsequently bought there. It's not because mine have failed and been replaced 'often'!
VicS
13 Jul 2002
The Annexe M "marine" regulators are corrosion resistant.
They also have other features, such as an overpressure relief valve and a reinforced diaphragm , compared to standard regulators.
  • Like
Reactions: GHA
PetiteFleur
29 Feb 2008
Suffolk
My experience - I bought a WHaward marine regulator from a supplier and it apparently failed after a few months, replaced initially with the original regulator that came with the boat and it worked fine. Spoke to WHayward Marine who said return it and we'll check. Came back to me and said there was nothing wrong with it, tested on different systems & appliances. They returned it and it's worked fine ever since. All I can think of is that it didn't like the winter cold at the time, even though the original regulator worked. Worked all this winter as well, so no idea what was the real problem. WHayward were very helpful though and would recommend them.
Refueler
13 Sep 2008
Far away from hooray henrys
Winter is your clue ....
The ratio of Propane to Butane makes a serious difference to cold weather use of 'gas' ... the more Propane in the blend - the colder the gas can work in. Butane does not appreciate 0C ...
Did you change cylinder while they were sorting your regulator ?
Bodach na mara
21 Aug 2002
Western Scotland
"Marine" = twice the price. 🙁
But it is required if the boat is to satisfy various regulations, such as the B. W. boat safety certificate, or coding to allow chartering. Also if you require a survey to renew your insurance, the discovery of a non-marine regulator will result in the requirement to fit one.
PabloPicasso
12 Feb 2010
I had some guests aboard and put the kettle on. First time this year I've used the cooker. Regulator didn't work. I took it off the bottle and sprayed some penetrating oil into the hole in the bottom of the regulator and it worked fine.
Thought it best to replace it. But probably better to get the correct marine type, if i can find one.
