VicS
I turn the gas off whenever I finish cooking ( no fridge ) no way would I have it on all the time I'm onboard - then I've seen a boat - 20' mobo - blow up courtesy of a gas snag, so it's off at the regulator all the time, only on when about to light the cooker - so I placed the gas locker ( yes it does drain overboard in event of spills and is ventilated ) and regulator within easy reach, which of course is not always possible.
I don't know about Propane but for Butane Gaz one should use the Marine ' M ' spec regulator, last I bought was around £30.
For anyone with your level of paranoia, or who cannot locate the gas locker within such easy reach, an electrically operated shut off valve ( located in the gas locker) might be a worthwhile addition, especially as it could be linked to a gas alarm which we are told, above, is essential. It should not, of course, be used as an alternative to closing the bottle valve at night or when leaving the boat
I dont think there is a marine spec 37mb propane regulator but a 30mb dual fuel ( propane and butane ) system has been standard fitting for caravans and boats for quite a few years now
