Gas Cylinders
KAM
6 Jun 2005
During the 4.5kg gas crisis I started filling my own camping gaz cylinders. I found them a bit small so have gone back to the 4.5 kg calor. I thought I'd filled one last year but can't manage it now. A web search was inconclusive as to wether calor have a non return valve. Anyone know? Flo gas won't fit my locker unfortunatly.
I’ve definitely filled the Calor 3.9kg propane from larger donor bottles, so no non return valve there, and I would be surprised if there’s a non return valve in blue bottles, though there will almost certainly be one in the regulator. Have you a ‘pigtail’ hose that’ll fit calor blue bottles? Should be straight enough process if so.
A friend recently bought the kit to transfer butane and we shared the cost. Two 907s filled from a 15kg Calor butane and the kit has already made a saving . Ongoing 907refills will cost £12 in gas at todays prices compared to £50 per 907 refill/ exchange from the marina. Both our boats have gas lockers designed specifically for Campingaz 907's so not viable to convert to a larger butane cylinder.
Donor bottle upside down with some gas in it? receiver bottle a metre below it? Both valves turned on? I can't think of anything else that would stop your transfer. I am decanting into Campingaz bottles, though.
Cheaper still if you fill your calor bottle at an LPG fuel station with one of these. Some discretion is required.
I suspect by discretion you mean filling of loose cylinders (at a lpg station) that are not intended/designed for self filling is not allowed due to the risk of over filling.
Yes, that's what I mean. I have a perhaps misplaced confidence that, when filling an empty cylinder, I can stop filling it after delivering 80% of its capacity.
Speeds things up if the donor bottle is a bit warmer than the recieving bottle. I put a towel over the donor bottle and pour some hot water over it.
