Thistle
After years of great service my Garmin GPS 12 seems to be dying. This leads to a couple of questions for the erudite panel ...
1. The set works well some of the time then suddenly cuts out, as though the batteries had become disconnected. This looks to be as though there is a loose connection / broken wire / dry joint.
a. Is this likely to be the cause or are there other possibilities?
b. My guess is that a return to Garmin is not likely to be cost-effective: any views?
c. If a paid-for repair is not worthwhile, how can I get into the set myself to look for possible causes? (I don't mind if, afterwards, the set is no longer waterproof (or guaranteed!!))
2. In the worst case, I'm going to want to buy a replacement. The GPS 12 does all I need both ashore and afloat. Which replacement sets should I look at? What justification can I offer the purser for any additional facilities?
TIA
Ian
TIA
Ian
