Garmin chartplotter charts
Lir
11 Feb 2007
Hi,
Are charts still available for Garmin 2010C chart plotters, I am looking for charts fo the Atlantic Island & Cape Verde?
Jon4468
11 Jan 2021
Hi,
You will probably find one on eBay, I think they are Bluechart?
It will be miles out of date now though as they are obsolete, as said above.
lustyd
27 Jul 2010
It supports map source so you should be able to load pretty much any Garmin chart from a PC as they’ve not changed their format for decades. Map source is available online and will install if you install Basecamp first. I find MapSource a really handy program for downloading routes etc. it’s the OG active Captain.
Might also be worth looking into a program called JaVaWa GMTK if you find some charts so you can take a full backup with codes to make sure you don’t lose them as cards can get corroded or whatever on the boat.
Refueler
13 Sep 2008
Far away from hooray henrys
I have a 2006C plotter sitting on the bench .... found it under the bunk on the boat I bought spring 2023 .... same problem ... discontinued charts ..
They use Bluechart and Mapsource based ....
You can find both on eBay - but they are old ! I don't mind expired charting - but they are even a bit old for me !!
