Dorset Dan
I won't say too much of the detail on here, but I have surveyed a boat which has some galvanic corrosion issues on the starboardside in particular (affecting prop, prop nut and more importantly p bracket bolt integrity). Port side generally OK.
I have used a surveyor and engineer who both come very well recommended on this forum and they have duly identified the corrosion issue, and recommended in their reports that the root cause of the issue be found and rectified prior to purchase (noted as a possible issue with the electrical bonding). Galvanic corrosion was also noted on starboardside in a previous survey a few years ago, and starboardside prop was changed only 2.5yrs ago (now severely pitted).
Whilst it could be a marina / stray current rather than boat specific issue, the fact that it was reported in a previous survey makes me think it is the boat itself......
Any recommendations as to who to use for this to test both the systems on the boat as well as for any stray currents in the water? I am thinking that a marine electrician who is suitably qualified / experienced in galvanic corrosion issues? Or if not a marine electrician, then who? Preferably within sensible travelling distance of Poole, Dorset.
