jpay
My Gallion 22 needs a couple of new things for the season...
The roller reefing drum is seized and although rolls in using the line, pulling on the jib sheets causes it to bend and the drum is very tight. The sail won't pull out. Obviously this is a problem and I want to address it as soon as possible. The mast is down and the drum is off but I'm not entirely sure if I'm replacing the drum, looking into it for the bearings or the foil needs attention.
Second question is the old sea toilet believed to be a simpson lawrence sl400 has been removed, I aim to fit something new. I know this model is no longer available but can anyone suggest a replacement. I would like it to be as low profile as the sl400 so I can use the v-berth double.
Final question... I've been offered the opportunity to fit an inboard engine, I know the obvious positives will be control in steering and more balance but how much will it affect the final price of the boat. If i was to sell I would like to make money not loose it...
Thanks in advance...
Jason.
Jason.
