Neeves
There is a thread over on Cruisers Forum on whether G40 or G70
http://www.cruisersforum.com/forums/f118/g70-chain-vs-g4-225019.html
G70 chain has had its ups and downs, mostly downs (due to galvanising quality) - but it does generate interest at least amongst a few of us - for those with no interest - move on, you might be bored!
What sparked part of my interest was an observation (sorry my usual long winded thread
I think I have this right - but I stand to be corrected.
Commonly chain is sold based on size and the strength of wire from which the chain is made. G30 is made from a wire with a minimal tensile strength of 300 MPa and if you happen to buy a lifting chain then G100 chain is bought with a wire strength of 1,000 MPa (or it is that strength when processed - usually Quench and Tempered). G120 is a bit of an oddball as it seems to be a G100 wire but the link size is enhanced (square links as opposed to round links was the first divergence). The manipulation of link size results in a bigger cross sectional area - and stronger chain.
This coincidentally resulted in 8mm G30 chain having a minimum tensile strength of the chain of 3,000kg and G40 chain having an MTS of 4,000kg. If you note Vyv's tests - actual strength of G30 is near, but not quite, G40 and G40 meets G40, just.
G70 is an oddball - hence the interest.
The biggest and most well established manufacturer of galvanised G70 is Peerless (owned by Kito), through their ACCO plant. They make their leisure marine G70 from a G70 Transport chain that they galvanise. So - they make their chain, from a steel alloy (I don't recall if its a Boron of Bismuth addition to the alloy) similar to the alloy but not identical to their G43 (transport) chain and then Q&T it. This gives them their G70 transport chain. They then galvanise this chain and the heat of galvanising re-tempers the chain and it results in a chain with a strength of 'about' G55 (but they still call it G70).
Quench and tempering is a re-crystalisation process, under controlled cooling conditions (which are proprietary) and I assumer the Bismuth or Boron additions help the control of crystal growth. I also assume other processors might use different alloys or different levels of the same alloy addition to suit their re-crystalisation schedules). Re-heating, galvanising, modifies the original tempering but subsequent re-galvanising will leave the chain with a similar strength to that imparted when first galvanised - so -regalvanising of G70 is quite possible - producing a chain of similar characteristics as was originally installed in the yacht (confirmed by a chain maker and independent tests)
Maggi who entered the market more recently seem to base their chain on a G100 product, which is also Q&T, but when they galvanise they again retemper and the strength falls - but to result in their having a 'true' G70 chain.
So the Peerless 8mm product has a strength of about 5,500kg and the Maggi product has a strength of about 7,000kg. In comparison 8mm G40 chain would be a 4,000kg MTS. So Peerless is a real step above G40, Maggi is a great leap above G40.
There is then introduced a fiddle factor Peerless gal G70 has a safety factor of 3:1 and Maggi chain a safety factor of 5:1. resulting in WLL of 1,800kg and 1,400kg. I think in fact West Marine tend to emphasise the WLL, of Peerless G70, and leave the buyer to search for the MTS.
There is only one other manufacturer of G70, of which I am aware, Campbell also in America (part of Apex Tools) but they appear to have no real interest in leisure marine (though they do make to 'our' sizes but only imperial). Maggi and Peerless make both metric and imperial.
Metric chain sizes are 'simple' (apart from 10mm chain which has 2 size specifications) but each imperial chain type/quality has a different link size, so BBB is different to G30 and different to G43 and different to G70 - resulting in windlass makers having a huge range of gypsies. Some gypsies are forgiving of some types, apparently, but check and double check.
When people talk about buying G70, or there is a thread about G70, these contradictions are, completely, ignored.
Historically if you were to option to alter to G70 having used, in Europe or America, a G30 then the rule of thumb was to buy the next size down. This same rule of thumb has been applied to Maggi, since they entered the market, even though their MTS is much higher and their WLL much lower.
Makes little sense to me.
We wanted to downsize our rode, to save weight) and there was no 6mm 'high tensile' galvanised chain - so we had our own made such that the end product had the same strength as the 8mm (Grade L in Australia - but the same as G30) we had been using. We did not try to match the specification, or Minimum Tensile Strength but match the Ultimate Tensile Strength. The chain we had made - was cheaper than standard Australian or CMP Chinese G30 8mm chain. We have been using it for almost 3 years now - without issue (it took time and effort - but well worth it, if you want to save weight).
Jonathan
Jonathan
