RobbieW
...Secondly, in a busy area you probably have channel bandwidth of 20 and the thing might be set to that, so go into the router settings and choose 40 (to double your speed, compared with 20, if no neighbour interference). On super-new stuff there is now 80, as well as 20 and 40
4. Just to be clear, if you are on 20 not 40 and have one channel not 3, you have max 1/6th of the claimed rating!
So in summary put the laptop near the router so that the short range of 5Ghzdoesn't hurt you, then select the 5Ghz band via separate SSID for the 5 (to distinguish from the 2.4) and set the channel bandwidth to 40 (or at least 20/40 auto) and you should easily stream video (assuming the remote storage device that the video is stored on is itself fast enough, but you knew that!)
Please dont set your bandwidth over 20 in busy places. The way the devices increase the throughput is to use more channels; with the bandwidth set to 20 you are effectively using 3 channels because the separation isnt that good, set it to 40 and you're now using 6 consecutive channels. There is some basis in the view that only channels 1, 6 & 11 should be used because the software in routers is better at dealing with competition on the same channel than it is dealing with overlap from other channels. Also turn the transmit power right down on your router and minimise the interference its likely to cause, its doesnt need to be high as most of us dont have boats that big nor with concrete walls!
