Fuse position
Cloven
17 Oct 2003
Scotland
On separate thread on solar panels, VicS stated:
"Don't forget appropriate fuses as close as possible to the battery in all wiring"
Please could someone explain why. I don't doubt Vic, just interested why.
lw395
16 May 2007
The fuse protects the wiring from catching fire due to something shorting the wiring.
The battery has the current capability to do damage, the solar panel does not, so you need a fuse close to the battery to potect the maximum amount of the wiring.
The wiring needs to be thick enough to carry anything the panel can produce.
Cloven
17 Oct 2003
Scotland
Does this apply to anything connected from the battery - ie VHF, Plotter etc?
rob2
23 Aug 2005
Hampshire UK
Yes, although it is not uncommon to find circuits fused at the switch panel rather than a single fuse on the feed to the panel (close to the battery). Ideally one should have both - a large fuse next to the battery protecting the whole wiring system and then individual fuses for each circuit taken from the switch panel.
Rob.
prv
29 Nov 2009
Southampton
Yes.
Any wire running straight from the battery is potentially dangerous, as a short-circuit in it will cause a spray of sparks and/or melt the wire. A decent-sized battery will melt a spanner across the terminals, let alone a puny bit of wire. Once the wire has passed an appropriate-sized fuse it is rendered safe, because in the event of a short the fuse will blow instead of the wire melting.
I have a 150amp Megafuse four inches from my service battery terminal, to cover shorts in the heavy wiring to the panel. The panel has an appropriate fuse on each circuit to protect the smaller wiring running out from there (which could melt without blowing the Megafuse).
lw395
16 May 2007
both +ve and -ve wires fused, or one only, if so which is best practice, please ?
In a car, with a metal body connected to _ve, you fuse the +ve, so if the fuse blows, that circuit is at body potetial, so the short draws no current.
In a boat, there is no 'body' and the engine may or may not be negative, but the principle is still good. IMHO, you should fuse all of the positives, or all of the negatives, otherwise there is some chance of two unfused bits touching.
Blown fuses in the negatives can cause the return current to flow via data lines in some things, which is not a good idea.
Keeping the negative continuous and un fused is a good system, but not the only way. It'sd what most equipment makers have in mid though, as anyone who's installed a stereo in a +ve earth Morris Minor will explain!
David2452
6 Jun 2001
London & Fambridge
All a bit over simplistic, an over current device is there to protect a circuit which includes the conductor but is not limited to the conductor of course and should reflect the downstream circuit. So whilst a fuse protecting say a conductor from the battery to a distribution point or power post may be appropriate to protect that conductor, there needs to be protection from that point to the almost certainly lower capacity circuit downstream of that, this can mean that between the battery and a load (plotter, bulb, motor etc.) there can be a number of gradually reducing value over current devices., each reflecting the lower value required downstream. For initial connection to batteries I prefer to use an MRBF as they protect every mm of the connected conductor unlike mega or midis which do not.
David2452
6 Jun 2001
London & Fambridge
Yes, this thread was prompted by the one in "the lounge" which referred to a garden shed solar panel but as the OP of this thread, I was referring to boats, hence this forum
Ah, I see, perhaps a link to the origonal thread would have helped, mind you, my comment on protecting every inch of the conductor still stands.
JumbleDuck
8 Aug 2013
SW Scotland
That's an interesting device; wasn't aware of such things.
I'm about to experiment with a couple of 250A circuit breakers like this
right beside the house and start batteries. If they prove over-sensitive to engine starting demands (the starter should draw 80A but may well take a lot more as it starts) I'll use fuses instead.
