Fuse panel for Katie L
Sailingsaves
26 Feb 2013
Not the exact answer, but...
even though not cheap (it was £10.99 when I bought one), but I bought one of these for my Dad for Christmas. Seemed good quality.
I liked the 2 USB slots of different Amperage (and the display indicates amps draw)
I liked the switch, so 3 plugs can be left in and push switches turn them on and off and a pretty blue light shines to show it is on too.
Display also gives voltage.
Comes with sticky back adhesive pad that actually stuff to dashboard (although we did clean it with brake cleaner first).
http://www.amazon.co.uk/gp/product/B00RFCV3XY?psc=1&redirect=true&ref_=oh_aui_detailpage_o06_s00
dylanwinter
28 Mar 2005
Buckingham
www.keepturningleft.co.uk
blackbeard
17 May 2003
Hampshire
Well, on my little Hunter ( a little bit bigger than Katie L, I admit) I have altogether, and that doesn't include the bilge pump which is auto:
GPS, pulpit bi, stern light, masthead ARW, masthead tri, radio, instruments, AIS, 'fridge, 12 v sockets, cabin lights, Yeoman plotter, domestic water pump
you might not need all those, and for some of them there's a switch built into the set (there is in my domestic radio for instance), but you will still need to fuse (or circuit-break) them. And it's useful to have a few spare switches/fuses just in case you need a few extra toys ... you can use in-line fuses but it's best to have labelled panel-mounted fuses or circuit breakers.
Incidentally. The first offering showed a battery condition meter which was, I think, moving coil. Waste of time, as it's not accurate enough. To measure battery volts, use a decent digital meter on the battery terminals. A rough idea can be given by the volts function on some GPSs or plotters, but (even apart from accuracy issues) the volts reading will be affected by current drawn and consequent volts drop in both battery and cabling.
dylanwinter
28 Mar 2005
Buckingham
Katie L is dead simple
nav lights are those led battery jobs - so no wires
a circuit for the two cabin lights
one for the echo sounder
charging camera batteries is my main concern
I can run the battery down as much as I like as the outboard is pull start
so the three gang is probably enough
D
VicS
13 Jul 2002
D
For someone who makes so much stuff why are you paying through the nose for for something that you could easily make yourself with the actual number of fuses, switches and sockets that you require.
FWIW I think I'd have a panel with the switches and fuses for the boat's stuff where most convenient for it and a separate panel with the sockets for charging stuff located where the stuff on charge can most suitably be accommodated.
Always worth having a spare switch of fuse, or the space to fit one later for some new bit of kit/gadget as electrical systems tend to grow.
I started with a panel with a fuse and a couple of switches but it grew into what you see in this rather poor photo
2nd_apprentice
18 Mar 2007
Berlin
dylanwinter
28 Mar 2005
Buckingham
that looks great
however, along with my cost avoidance strategy I also have the fix less and sail more philosophy
so an off the shelf panel it is
bought this
http://www.force4.co.uk/department/...-panel-with-2-x-12v-sockets.html#.VRUbCOEQOXh
ghostlymoron
9 Apr 2005
Shropshire
A bit pricey but Blue Sea stuff is v well made and will do the job for you. You can get flush fitting dual USB adapters that will convert cigar sockets which could be useful now that a lot of gadgets are USB.
MagicalArmchair
11 Jan 2013
Kings Hill, Chatham Marina
Looking at this job on Triola - all the breakers on those Blue Sea panels are 15A... is that a problem? Surely you want most stuff to blow before 15A! Hence I am once again favouring a fuse panel where I can choose the fuse and just keep a bloody good stock on board.
CreakyDecks
9 Sep 2011
Breakers are meant to protect the wiring, not your equipment.
dylanwinter
28 Mar 2005
Buckingham
That's incorrect. You can design your wiring to withstand 15A but that's not going to do you much good if the equipment itself catches fire.
you make a good point
what sort of gear is likely to catch fire?
could a vhf radio catch fire I wonder?
if 15 amps enough to stop a wire from getting hot enough to catch fire?
I am assuming that the internal lights are likely to blow before they catch fire
got me thinking now
D
PS force 4 can't deliver so ordered this instead
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItemVersion&item=161570275783&view=all&tid=1237510969006
prv
29 Nov 2009
Southampton
Potentially, if something short-circuited inside it. Probably quite unlikely with a modern radio that's all PCBs inside a plastic case, more plausible with an older metal-cased radio with wires inside. The wiring to it is usually meaty enough to pour plenty of energy into the short.
From memory, 1.5mm2 wiring is rated at 15 amps, so this size wiring would be safe with such a fuse. But tiny wiring might not be.
AndyJ76
25 Oct 2012
Once, when I was young and foolish, I installed spot lights on my car to an unfused switch. I'd connected the live to the switched ignition terminal, and the blade of the control switch touched against the chassis. I had wrapped the excess wire round and round the steering column (see previous statement).
The wire instantly started glowing cherry red, the insulation vapourised and I managed to avert disaster by striking the starting-to-melt wire with a key or something, it broke. Phew
